Changed wifi and now I need to press sync button on back of doorbell to get it working again. Any suggestions how I can remove the doorbell from the mounting bracket?
The small tool that smartphones use to remove the SIM card and micro SD card will also work. You could also try a tooth floss pick. Good luck!
Can you use a small paperclip or other small, thin wire and bend it sufficiently to create a curve that will suffice? I guess a worst case choice could be to chisel/drill a small channel in the stone for access.
Of course, a possibility would be to simply rename your new WiFi SSID to match the old one.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
