  • 2 Replies
  • 1054 Views
Fluf_Meowerson
I mounted my doorbell right above a stone ledge on the outside of my house. Now I cannot access the removal hole at the bottom of the mount to release the doorbell from the mount.
Changed wifi and now I need to press sync button on back of doorbell to get it working again. Any suggestions how I can remove the doorbell from the mounting bracket?
FloridaBuckeye
The small tool that smartphones use to remove the SIM card and micro SD card will also work.  You could also try a tooth floss pick.  Good luck!
Can you use a small paperclip or other small, thin wire and bend it sufficiently to create a curve that will suffice? I guess a worst case choice could be to chisel/drill a small channel in the stone for access.
Of course, a possibility would be to simply rename your new WiFi SSID to match the old one.
FloridaBuckeye
  • 2 Replies
  • 1055 Views
