Local Storage of Videos not working
The use of local-only recordings won't give you thumbnails until you select one to view. Does the local storage setting for the base/hub show the storage? Remember that it has to be at least 16GB to be used these days (firmware change). If you safely eject the drive and view on a computer do you see the videos? Any and all details will help.
Hi jguerdat, thanks for the quick reply!
I have local recording turned on. I have a 60gb sd card inserted. I've armed the doorbell to record when motion is detected. I've walked past the doorbell multiple times and when I do I get a notification that the doorbell has detected motion but when I look on my Library tab in the Arlo iOS app I see "no recordings". I have it set to "if motion detected: record video". No video. I've ejected the sd card to see if it's simply stored there (and not updating with a thumbnail in the app) and have not found recordings since I started this troubleshooting process.
Update on specifics of this troubleshoot: ONE of the Arlo Pro 2 cameras will record when armed in the default "Armed" mode setting. The second Arlo Pro 2 camera and the Video Doorbell do not.
The same is true when I use a custom mode where it's strictly the doorbell recording on motion, it never records to the library.
All of these individual cameras all have the same rules applied. When there is motion they start recording. Still, only one camera records to local storage.
I think it's time for a system reset. Remove all devices from Settings, My Devices and start fresh. Be sure to note all settings, modes, rules, schedule, etc. to speed the rebuild.
Hey jguerdat,
I've followed instructions you've listed. Since this process I now have the two Arlo Pro 2 cameras recording local but the video doorbell still does not record to the local drive. I receive simple motion notifications from the doorbell but nothing else. I'm working from the default "Armed" mode only.
What am I missing?
The doorbell has to be connected to a base or hub for local recordings. Connection to WiFi doesn't allow this.
The video doorbell has been connected to the base station for each system and camera reset variety I've tried in the past four days.
You got me there. All I can suggest is to use the Contact Support link at the bottom here to see what they might suggest.
Thanks for trying jguerdat! I really appreciate it.
Update for those with the same issue: I reached out to support and they asked me to do the same things I've already tried here. I replied with the info they requested and it's been a month with no response.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
