Installation hardware included with video doorbell
The wirenuts provided with the video doorbell, even though they are the smallest available, are too large to fit behind the video doorbell. I am mounting on brick and it's not easy or convenient to drill a larger hole to tuck the wirenuts into. My solution was to use crimp-type butt connectors which can be made much smaller. I believe it would be a good idea to include two of those as an optional way to connect the unit to existing wiring for those dealing with brick mounting surfaces. Should only cost 3 or 4 cents.
cmipilot,
Good feedback, I will pass this along to the development team for consideration.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
