Installation hardware included with video doorbell
  • 1 Reply
  • 1647 Views
cmipilot
The wirenuts provided with the video doorbell, even though they are the smallest available, are too large to fit behind the video doorbell.  I am mounting on brick and it's not easy or convenient to drill a larger hole to tuck the wirenuts into.  My solution was to use crimp-type butt connectors which can be made much smaller.  I believe it would be a good idea to include two of those as an optional way to connect the unit to existing wiring for those dealing with brick mounting surfaces.  Should only cost 3 or 4 cents.
cmipilot,
Good feedback, I will pass this along to the development team for consideration.
  • 1 Reply
  • 1648 Views
