I want to replace older model AVD1001-1CCNAS with new model AVD1001. We are hard wired.
I want to replace older model AVD1001-1CCNAS with new model AVD1001. We are hard wired to previous door bell wiring. What do we need to do to install the new door bell? We just purchased the newer model.
You listed the same model twice but I'll wager you really meant the new one is the AVD4001. In any event, the new doorbell can be used both wired as you have now or without the wiring. So, all you need to do is to remove your current doorbell both from your account as well as physically and then install the new one using the app's procedure. It's possible that you're still using the old user interface (UI) that uses Library to view recordings so installing the new one will force a migration to the new UI that uses Feed. I'll post some links to help you understand how the new UI works. It's important to note that custom modes don't transfer, you can't create new custom modes and the layout and usage is noticeably different than you're used to. Also, you can't go back to the old UI for any reason.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Schedules:
https://kb.arlo.com/000062942/How-do-I-add-a-Schedule-Automation-to-my-Arlo-system
Geofencing:
@jguerdat wrote:
all you need to do is to remove your current doorbell ... physically
@bernardjmitchel : Just want to add that this includes the backplate, as that only fits the AVD1001 model.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
