I have two mechanical chimes -- how many power kits do I need?
  • 2 Replies
  • 2661 Views
joyjit
Hi,
I am thinking of buying the Arlo Essential Wired Video Doorbell .
My house is currently wired with a traditional (push button) doorbell, and TWO mechanical chimes (one upstairs, one downstairs). The transformer is NuTone C907 16V 30VA
Would I need to connect a power kit to each of the mechanical chimes? If so, where can I get an extra set? (the box includes only one)
Thanks very much in advance for your help.
If the two chimes are wired properly (in parallel) you only need one power kit.
You can check that they are in parallel by simply disconnecting the wires on one of the chimes.  If the other still rings when you press your existing doorbell, then they are wired in parallel.
Some chimes aren't compatible - what model(s) do you have?
joyjit
Thank you @StephenB
As pointed out by you in this other thread, I did verify that my two mechanical chimes are wired "in parallel" to each other.
I have now installed my Arlo Video Doorbell (Wired) with the power kit installed on one of the mechanical chimes.
And everything works great.
(And I have the Newhouse Hardware CHMI1 chimes)
  • 2 Replies
  • 2662 Views
