Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error
  • 7 Replies
  • 1869 Views
xinjing
I want to enroll in arlo secure plan but I can't login my account. It always shows 'Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error' for several days. Any suggetions to solve this problem? Thanks.
7 REPLIES 7
xinjing,
Are you seeing this error when using both the web client and mobile app? In what country are you located?
xinjing
Just web browser, and I am in MD, US.
xinjing,
Are you using a VPN? If possible, are you able to test from a different network to see if you still experience the same issue?
Retired_Member
Not applicable
I’m the exact same and it’s so frustrating. In New Zealand. Arlo is useless and doesn’t even have a direct contact email to try and fix
xinjing
I turned off the VPN and still had the same problem, but there was no problem logging in with the web browser on the phone, so I used the phone to enroll the security service
xinjing
I have no problem logging in with the web browser on my phone, you can try it.
Seinafo,
Are you experiencing this issue when using the mobile app? As mentioned here, if you log in using the browser, do you still experience the same behavior?
  • 7 Replies
  • 1870 Views
