If you go into Mode and select the edit button, you should get a rule that says if motion on doorbell.. Click edit button next to it. Should see detects motion.. Check Do Nothing below it.
I have the wired doorbell, but the app should be the same
In Mode, select doorbell. Set the rule "if motion detected" then "Do nothing". It should stop recording. Not sure about the doorbell press, never tried it.
Seems a waste of what the doorbell is for. Have you tried turning the sensitivity way down in mode?
While I'm not on a busy street, I do get false triggers from cars. I use a zone that easily excludes the street and am currently using a motion sensitivity setting of 25 which has eliminated almost all such recordings/notifications.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
