How do I continue to record video locally to watch back without getting a subscription
  • 1 Reply
  • 1059 Views
bleelikewater
I do not want a subscription.  How do I continue to record video locally to watch back without getting a subscription
You need to buy a SmartHub and connect all cameras to it. Once that's done, you have to use the hub's settings to set up local recordings/storage using at least a 16GB drive. Checking local recordings depends on which user interface (UI) you're using - the old one which uses Library to view videos or the new one that uses Feed. Note that this is NOT the app version.
https://kb.arlo.com/1146857/How-do-I-set-up-local-storage-backups-using-my-Arlo-Base-Station-or-Smar...
or
https://kb.arlo.com/000062818/How-do-I-set-up-local-storage-backups-using-my-Arlo-SmartHub-or-Base-S...
  • 1 Reply
  • 1060 Views
