  • 2 Replies
  • 1129 Views
amymcarraway
 The front panel is separated from the device. Having to tape it down. Please advise.
I would check with Arlo Support re possible warranty.....
https://www.arlo.com/en-us/support/contact
If more than a year old and no warranty, I might consider CAREFULLY using some form of epoxy.... using like a toothpick so not over applied.
DelsoGrace
Very similar situation here! I noticed the discoloration/ability to see the chip in the middle. I’ve opened a support case that is being sent to the Safety and Hazard team. I am just waiting for them to tell me it’s 2 months out of warranty…
  • 2 Replies
  • 1130 Views
