Drill Bit Size
  • 1 Reply
  • 3998 Views
lopez31
Does anyone know what size masonry bit to use to be able to mount the arlo video doorbell? Is it a 6mm?
Thanks in advance!
lopez31,
Yes. You'll want to use a 6mm drill bit to drill 2 holes where you want to mount the doorbell.
  • 1 Reply
  • 3999 Views
