Doorbell not recording
From 2/17 -2/23 the doorbell would only record if I answered the phone notification after someone rang the bell. The 24th, it began recording everything again. It has dropped off two more days now. I have changed nothing. I have not done anything either before it stopped recording nor to try and fix the issue. Arlo is stupid expensive. And while they should be dummy proof, even if I am a dummy, I haven’t changed a single thing with the system.
If the responses to reset anything, OK. Then what? The point to these things is to surveil when you are not home. I do not check my library with any regularity to alert me that is not working. How would someone reset it if they are away for an extended period?
Thank you.
BCQ,
If you're using the default "Armed" mode, the doorbell should produce a recording when it detects motion. You could try creating a new custom mode to test if you still experience the same behavior.
If you live stream, are you able to manually record? Does the recording arrive in the library?
I do not live stream. I am not even sure I know how to do this. Regardless, it is incredibly frustrating that it is not recording. I have had to reset my devices more than once in the relatively short time that I have been using them.
BCQ,
If you're continuing to experience this issue, I encourage you to reach out to the support team here, to investigate further: https://www.arlo.com/en-us/support/contact.aspx
You will find several options for contacting support in the provided link.
I recently started experiencing strange recordings when motion activated. About 2 weeks ago, it stopped recording short motion activated periods. It used to show a total video time, I.E. 9:56am 0:15 Person. Now i get the time of day, but the duration says something like 362:34:24 Person. When you select that event i essentially get a snapshot and no video.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
