Doorbell does not ring when pressed
  • 1 Reply
  • 1620 Views
Lind
My standard doorbell does not ring when someone rings my Arlo wired doorbell. Can I add an Arlo chime to use for an inside doorbell sound. Also, can you turn off ringing your cell phone and then just use the chime?
Yes, you can use the Arlo chime instead of a traditional one.
Check the doorbell settings for Silent Mode. Enabling it gives you 2 options to do what you need.
  • 1 Reply
  • 1621 Views
