  • 9 Replies
  • 1775 Views
Booboocraig69
I have done all the recommended things to get my bell working .. have charged for 48hrs and my bell is still dead
9 REPLIES 9
We need a lot more details. Charging takes ~6-7 hours and turns the LED from red during charging to green when charged. Do you see that?
Booboocraig69
We charged the battery for over 24hrs and have even bought a new battery and charged it … the doorbell still doesn’t work ….
The battery is green after charging we place it in bell (doesn’t light up ) take battery out and when you plug it in it’s back on red
That's normal but it should turn green fairly quickly, maybe in a minute or two.
Anyways, I don't think the battery is the issue. Tell us about the doorbell, process you've used, what you've tried and what you see.
Booboocraig69
We have reset the doorbell and nothing happens … press button on doorbell for 10+ seconds nothing
You may need to hold the little button for >15 seconds to cause the reset to happen. When you do that, does the ring start flashing on the doorbell button?
Booboocraig69
Have tried holding for 15 seconds and nothing the bell is totally dead
Is it still under warranty?
Booboocraig69
Hope so it’s a year old
Warranty is 12 months, so I suggest contacting support ASAP.  Use the options in the app - googling support will likely lead you to a scam support site.
  • 9 Replies
  • 1776 Views
