Doorbell chime AVD - 1001
I think that I figured out the solution for the chime not ringing on this model. Although you can test the chimes during installation, and they work, the chime does not work if you choose the option "None" (from the instructions), and keep that setting. After following all the community solutions, I decided to try the "Digital" setting, and it works after fully installing. Try that before following all the other solutions from the community. It may save you a lot of time and head-ache/scratching/banging.
My chime is not working even though I fitted a new chime box. My app on my phone does not include any chime options. Do I have the correct app?
A traditional chime?
Or one of the Arlo chimes???
Did you install the power kit? Also make sure the switch is in the "O" position.
My original analogue chime did not work so I bought a new analogue chime. Yes, power kit fitted set at zero.
Did you set up the chime in the app when you installed the doorbell? Look in "chime settings" in the device settings for the doorbell.
If if you didn't, then I think you need to remove the doorbell from the account and install it again.
Thanks for reply. Currently the app on my phone only shows "chime not connected" with no options to configure. There is a voltage across the chime box so I think it is connected to the door bell. Are you saying the app will allow me to configure the chime if I reinstall the doorbell?
Yes.
Thanks for your help. I'll give it a go.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
