All cameras newer than the Pro 2s require a subscription to record to the cloud. If the doorbell is connected to your base/hub local storage can be activated so you have those recordings without a subscription.
Same!! How do we get recordings now?
Has the trial subscription expired?
@Angelah120 wrote:
I am guessing since my trial is up it will not store unless I pay monthly. If I would have known this I would not have bought it.
Yes, as I said it requires a subscription for cloud storage. FWIW, that is printed on the box (twice I think).
I am also having this same issue with the video doorbell. I don’t care about cloud storage but would like the videos to be stored in the hub library like the other cameras. Can’t I do that without a subscription?
Frank2,
By default, Arlo devices are set up to store content to the cloud. To utilize local storage, you must set it up. For more information, take a look here: How do I set up local storage backups on a USB device using my Arlo base station?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
