  • 9 Replies
  • 2336 Views
  • 2 Likes
jskitchen1
When in Silent mode I turn off the chime but keep on the incoming call, but the incoming call does not work. If I turn off incoming call but turn on the chime, I still get incoming call. So the options do not work so I have to keep silent mode off. Has anyone seen a fix or is this something that is just waiting for an update.
9 REPLIES 9
ShayneS
Hi @jskitchen1
Which version of the Arlo app do you have installed? Is this occurring on iOS or Android?
When selecting these options are they Green or Grey?
Green will be the ON mode and Grey will be OFF.
Thank you
jskitchen1
This is on IOS and the app is version 4.8.1 (6798). I have it with Silent Mode Green and Incoming call Green. I leave Traditional Chime off (grey).
ShayneS
Can you remove app and reinstall the latest version 4.9 and try again.
jskitchen1
I deleted app, installed 4.9 and set silent mode green, incoming call green, and traditional chime grey and pressed the doorbell and I got no call.
ShayneS
@jskitchen1 I received the info, I will pass this along now and report back as soon as possible.
Thank you !
ShayneS
ShayneS
Hi @jskitchen1
The behavior you were experiencing should be resolved with the latest firmware version. Can you verify that your device is running version 1.19.0.0_3_098d492_3567407  and test again.
Thank you
jskitchen1
My issue has been resolved with firmware version 1.20.0.0_7_b366ce8_06b57e7
Thank you!
ShayneS
Thanks for the update.
  • 9 Replies
  • 2337 Views
  • 2 Likes
