FreedMD,
If your kit is missing the required mounting bracket, please visit the following link and fill out the form to request a replacement: Missing Flat Mounting Plate
The black piece on the back is the mount (there is also an optional angled mount if you happen to need that). Follow the install directions and it will step you right through popping the back off using the little metal push pin so you can mount the doorbell.
FreedMD,
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
