Doorbell Keep disconnecting
  • 1 Reply
  • 581 Views
Mejiasvega
My Doorbell ( ADV1001) was connected since 09/28/2021 without any problems, just suddenly started disconnecting on its own. Someone messed with the new Arlo update.
How is it connected - to your WiFi or to a hub? Have you rebooted your router or hub? Have you restarted the doorbell via the app in the doorbell settings? Has a 2.4GHz wireless device been moved or installed near the doorbell that may be interfering with the signal?
It may also be a faulty device. If still within the warranty period, use the app and go to Settings, Support, choose your doorbell and scroll down to Contacts to talk to official support for a possible RMA.
  • 1 Reply
  • 582 Views
