Connecting video doorbell to hub
What model hub/base? Are you trying to use the app or the web? The web page doesn't give you the ability to see local recordings. The app allows you to see local recordings but not on all bases (needs a VMB4500 or higher) so you may have to eject the drive to see videos on a computer.
Not the VMB4500. It needs a VMB4540 or a VMB5000.
@Dazlin1 wrote:
Come on. Seriously? This video doorbell is worthless to me. I have the 4000 hub. There is 1 catch after another.
The guy in tech support should have told you what bases were needed. They are listed in the article here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Note I don't work for Arlo - I'm just giving you the info.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
