  • 7 Replies
  • 1500 Views
  • 5 In Conversation
megalosworld
I’ve been trying to set up my wired Arlo Video doorbell and had been unsuccessful.  I followed all directions but it’s not connecting to the WiFi - I plugged in and unplugged the base station and still nothing. I met the WiFi requirements.  I don’t know what else to do. Please help!!!
7 REPLIES 7
What base station do you have?
megalosworld
@StephenB I was able to connect using my base but I’ve read that I don’t have to. When I ring the doorbell, it calls me. I don’t want that I‘d like to use Wifi instead but I’m still not able to connect.
When I ring the doorbell, it calls me. I don’t want that ...
Changing over to wifi won't change that behavior.  It will still call you.  So if that is the only reason for switching to your home wifi, then I suggest that you leave well enough alone.
To connect to your home wifi, you need a 2.4 ghz network.  It is important that both the network name (SSID) and passphrase be entered correctly - both are case sensitive.   Otherwise the QR code will have the wrong information in it.  Also, it can be tricky to get the camera in the doorbell to focus on the QR code.  So you might need to move the phone (further away or closer) to get it to find it.
There is some more info here: https://www.arlo.com/en-us/images/Documents/ArloVideoDoorbell/arlo-video-doorbell-um-us.pdf
peterzoetermeer
Hello I have the Wireless doorbell , but I can only connect on wifi, my cams connects automatic the base, but my doorbell won't do that,! he have the newest firmware, I reboot the base station, but only the 2.4 works whit the QR code please help
You did read where it states the WIRELESS doorbell is WiFi-only right now, right? The wired doorbell can connect to either a base/hub or WiFi.
megalosworld
yes I am aware of that - I’ve been having issues with this doorbell and it’s very frustrating.  There are days that the doorbell is working, one day the camera will work, there are days both are working then there are days nothing! Very frustrating.  I’m ready. To return allllll of the arlo equipments
ShayneS
@megalosworld
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 7 Replies
  • 1501 Views
  • 5 In Conversation
