Buying a Wired Doorbell. Will I need an Arlo hub ???
  • 2 Replies
  • 1297 Views
DelBoy1973
I'm thinking of buying the Wired Arlo Doorbell (AVD1001-100EUS)
I am wondering if I need the Arlo Hub to use this or can I just use it through my Wi-Fi and mobile phone, and also view it on my Google Nest Hub (2nd gen)..
I'm aware I will need to change my power supply, as mine is currently only 8 volts, but I need to know if I need anything extra to make this work straight out of the box, or if I will need the Arlo hub etc.. I'm aware I need the subscription for storage etc etc..
Roy
Using the doorbell with your WiFi works fine - no base or hub needed. The directions for adding devices to Google Home are found here:
https://kb.arlo.com/000055108/How-do-I-connect-my-Arlo-cameras-to-Google-Home
DelBoy1973
Many Thanks
  • 2 Replies
  • 1298 Views
