Arlo doorbell installation without existing doorbell chim
Hello
I would like to know if the doorbell has a complete wireless installation possibility.
I don't have an existing doorbell installation but only 3 arlo pro 2 with base home station.
Thank you
It requires power to run. There's a battery inside but it's to supplement the existing power on occasion and won't run the camera. I use an external transformer that plugs into an outdoor outlet to power my doorbell since I also don't have available wiring.
https://www.amazon.com/gp/product/B07VT6ZH5R/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
An internal wall plug would be fine as long as the wire doesn't get pinched, cutting the insulation, as well as making sure there's a drip loop in the wire so water can't run along the wire into the doorbell or wall socket.
The doorbell will call the phone when pressed but you could also add an Arlo chime if you have a base station to connect it to.
alarm
Arlo Video Doorbell
Doorbell
