Arlo Wired Video Doorbell picks up all vehicles that drive by
Arlo wired video doorbell picks up all vehicles that go by on street in spite of my having the motion sensitivity set clear down to 1 in settings and in mode. It also goes off line frequently and when I check settings they are back up to 80. Any suggestions would be appreciated. Tired of deleting hundreds of vehicle videos!
The motion test is just a test to get a number to put into your modes and rules. It will reset to 80 every time you leave the test. However, you've already turned the sensitivity down in your modes and rules (note that turning it down all the way does not turn it off but just reduces sensitivity). Since the doorbell can't be moved, use an activity zone (doorbell settings, Activity Zones) to eliminate the street.
Thanks. The street is directly behind my our front door so how would I set it to pick up whomever comes to the door, but not still have it picking up the vehicles going by directly behind that location?
If you have a subscription, you can turn off notifications for vehicles. You'll still get the recordings though.
Activity zones might be another option.
And of course reducing the motion sensitivity in the rule(s) - though that can result in missed detections, so there is a balance there.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
