Why does it seem as if the doorbell loses connection, more specifically the internet goes out for a split second, it will give up and not try to reconnect again? Every other device I own knows to automatically reconnect, no matter what issue.
Can we please fix what should be common sense for the device to iteratively try to reconnect to wifi until it succeeds, or at least provide an option in the app to try reconnecting without requiring me to take the doorbell off the wall and use that tiny key to press the small button.
Matthew_S,
Was this a one time issue or are you still experiencing this behavior?
I am having the same issue. It worked great for a month or so then my doorbell wanted to update the firmware and it did not after no matter what I try. Arlo has sent me a new Doorbell and the same thing happened. I asked if it would have the latest firmware and was told yes. Installed the new Doorbell and it worked for a few minutes before forcing me to install the new firmware and now it hasn't since. VERY frustrating!
The problem has appeared to be pretty consistent. I know for sure after the events I mentioned (ie power outage, resetting router, etc...), the problem is consistent on not reconnecting. I will need to reset and pair my doorbell after each of those occurrences. It's hard to tell if it ever disconnects under any other circumstances and reconnects automatically (ie the doorbell simply loses connection for a minute), but I have not noticed that yet, so I can't say that for sure.
Appreciate any help. Thank you.
I fitted the DoorBell it decided it was warming up and yet the outside temperature was 11C so not exactly freezing. Please to say it got through that but after a few hours it then lost Wifi. I had the go through from the start to get it working again.
It was fine over night and dropped out of WiFi again today, two days and two outages!
It does not seem to reconnect when there is an outage which is a standard by which all other WiFi devices normally operate. The loss of a WiFi connection for a short period is not unusual so most devices reconnect as soon as they find a signal but it seems the Arlo Video Doorbell does not do that. Why is it happening, is it a design fault and what can be done about it because it is useless when it is not working.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
