  • 2 Replies
  • 1518 Views
Sam_1122
Arlo Wired Video Doorbell: Installation problem - Installed the newly purchased doorbell device and cannot complete the setup. It has solid white light circle (which means has power for it) but does not sync with my home Wi-Fi. I have Verizon 2.4 GHz capable network. I do not get the flashing white light. I spent about half of my day time in installing and troubleshooting for the issue - no luck. Can someone help? Thanks in advance.
Did you check the FAQs here in the support section? There's a reset procedure you can try:
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Video-Doorbell
Sam_1122
Thank you! I went through the reset process and it works. Great.
  • 2 Replies
  • 1519 Views
