I recently purchased and installed the Arlo Video Doorbell. It works great during the day, but it struggles at night. Most of the videos become blurry and pixelated. Recently I also noticed that the video playback will just be a green image. Not sure what is up but I am hoping it is a software issue.
The firmware resolving this issue is now available. Check Settings > My Devices > select your doorbell > Device info to make sure your doorbell has the latest version posted here: Arlo Video Doorbell AVD1001 - 1.14.0.0_1189_4e1d685_817336 - 15th March 2022
If your doorbell is still not on the latest version, allow the firmware update to take place automatically overnight and test again to see if you still experience the same behavior.
Best answers
We're currently reviewing a possible solution for these reports. I'm not able to provide an exact timeline for release but this will likely be available in a future (within the coming weeks) firmware update.
I will post new information as it becomes available.
These are different symptoms of video corruption - usually caused by issues with the wifi link. Though of course it could be software.
What signal strength are you seeing? Is there outdoor lighting or some other electrical device that might be turning on at night, and generating some interference?
@JPav80 wrote:
I also will note that the green image is only shown using a web browser. If I use the android app on my phone I only see the pixelated laggy images.
FWIW, that also points to a damaged video bitstream. Various decoders handle bitstream errors differently (since the standards only speak to decoding conformant bitstreams).
But software/firmware issues can result in corrupted bitstreams, so that is a possibility.
You could try contacting support (using the link in the upper right of the forum page).
Attempted a factory reset which seemed to help for a day and then the issue came back. Maybe the camera's night vision is interfering with itself since I don't believe there is any source of interference that would only occur at night. Daytime videos look great and have never had an issue.
I contacted support and will see if they can figure something out other wise this will go back to Costco.
So I created a case, received a ticket# well over a week ago and no response yet from Arlo Tech. The automated email said it would take a day or two. Definitely not impressed.
JPav80,
Do you have a ticket number I can refer to? If so, please provide your support ticket and I can escalate requesting a status update.
The ticket# is 42734660. I finally did get a call this evening and it appears I am getting a new replacement after reviewing all the troubleshooting performed. If it doesn't resolve it then the agent was going to escalate further to see if it might be software related. Hopefully it is just a faulty unit but we will see.
I received the new doorbell camera and installed it yesterday evening. First few night time videos were ok but like the first camera, the remainder of the videos began having the same distorted video. That is the same behavior of the original camera. I updated my case online and hope to hear from someone soon.
Here is a sample from new camera
https://my.arlo.com/hmsweb/users/library/share/link/D3B318DEF561AEFF_202112
I’m really getting fed up with my Arlo video doorbell! 😞
I bought it through Costco and am within the year warranty so a return is very possible.
Ring video doorbell is seriously becoming a possibility. Given that Arlo is so lacking in addressing this issue, I’m really considering this option. There is no excuse for them not to come out with a firmware update!!!
Hello Arlo……are you listening?
No resolution yet, but according to the tech support person I have worked with states this is a known issue and their engineering team is working on it. Hopefully something soon!
Same issue - green pixel box only at night. Pretty much since day 1. It is very frustrating!
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
