Arlo Video Doorbell Audio Recording Adjustments
To be able to change/edit/switch off Audio/Sound Recording on the Arlo Video Doorbell.
I live on a reasonably busy street and every single time a car drives past, I’m notified about motion even after I have set the Activity Zones and that the motion is being detected outside the Zones, I believe it is actually picking up the Audio which is then effectively telling the Video Doorbell to start recording and depending on your notification settings, every single sound that is picked up prior to any actual movement happening, you are notified of “movement”
Arlo Video Doorbell
XPLCIT,
Arlo Video Doorbell will trigger only on motion detection, not audio.
If you're experiencing too many motion detection alerts, you might try adjusting down your sensitivity until you achieve the desired results. To adjust sensitivity, take a look here:
How do I change the motion sensitivity on my Arlo camera?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
