When Smart Notifications are enabled on my Arlo Video Doorbell Wired, my other Arlo Pro 2 cameras cannot activate the doorbell to record using cross triggering. It works fine if smart notifications are turned off on the door bell. Also when the doorbell has smart notifications on it can trigger other cameras but not the other way around.
srinkus,
Is this intermittent or does it always occur? Are you using any activity zones?
Yes it's always the case, and the doorbell is using activity zones.
srinkus,
Try disabling activity zones and test again to see if you still experience the same behavior.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
