Arlo Doorbell Setup - Without no doorbell connection
  • 6 Replies
  • 1903 Views
leo2023
Hello Everyone,
Got the costco bundle recently and the pro cameras are easy to setup with the base station. Our town homes are constructed in 1980 and unfortunately dont have any kind of doorbell connection. Whats the best way to setup my arlo video doorbell? Do i need to get any additional equipment for it to work?? Let me know. I saw something for nest but i am a complete rookie trying to secure the surroundings and any helps is appreciated. Thank you !!!
Costco Link: https://www.costco.com/arlo-doorbell-bundle-with-2-arlo-pro3-cameras.product.100532304.html
6 REPLIES 6
The video doorbell requires a doorbell transformer which you likely don't have. I use a plug-in transformer to provide power which I've plugged into an outdoor outlet and hidden the wire as best I can.
https://www.amazon.com/gp/product/B07VT6ZH5R/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It may depend on whether you own the town home or renting. It also depends on whether you want to plug a transformer in outdoors or somehow snake it out from an indoor plug. You could potentially install a regular doorbell transformer and wire it normally (or have an electrician do it).
leo2023
Thanks for your reply, we are renting the townhome currently . So I I get the transformer like you mentioned since the apt doesn't have a existing doorbell or chime may I know how does the sound or where will it come from ? Do I hAve to setup anything else ? I have echo and Google home ??
So the regular door bell transformer actually with the sound one ? And replace the outside with the Arlo bell once it's installed ? Am I correct ?
leo2023
the one in the earlier messages was out of stock, will this work? All i am doing is plugging the amazon one directly to the doorbell? FInding a powersupply inside? Correct??
https://www.amazon.com/Adapter-Compatible-Doorbell-Transformer-Certified/dp/B087RNLKRF/ref=sr_1_5?cr...
The transformer you found should work since it has the same specs as the one I used.
The sound will come from your phone when the button is pressed. You'll get a "call" - it seems like a regular phone call but it's not. You could add the Arlo chime but you'd also have to buy a base station to make that work. As for using an Echo or Google home, I haven't tried that so I can't be sure.
I'm not sure what you're asking here.
leo2023
So getting the Amazon one which you said will work but have to plug it inside the house and skip the chime part , that is it for the setup correct ??
If you plug the wall transformer into an indoors outlet, you'll have to find a way to run the wire so it doesn't get damaged when opening and closing the door. Otherwise, that's all you need to do to get the doorbell to work - no need to use the power adapter that comes with the doorbell since that's for an existing chime. When someone pushes the doorbell, you phone will ring and you can proceed as you desire (answer the call, decline it or just go answer the door).
  • 6 Replies
  • 1904 Views
