AZ
My doorbell here in AZ in the shade exceeds 110 and shuts down.
Never had a product designed for outdoor use that didn't work ant this temp.
So frustrated with Arlo not providing a fix or replacement.
The recommended operating temperature range for Arlo cameras and doorbells is -4°F to 113°F (-20°C to 45°C). However, Arlo cameras can overheat in very warm environments, especially if they are plugged into an AC power adapter. To prevent overheating, you can:
- Move the camera to a cooler location
- Remove the camera from direct sunlight
- Place the camera in a location no hotter than 104° F (40° C)
If your Arlo camera reaches a critical temperature, it will shut down for safety reasons and turn back on once it has cooled down.
Arlo batteries will not charge at temperatures below freezing, even if the camera is plugged into AC power or using an Arlo Solar Panel.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
