So I also replace my door chime and shut circuit breaker good half hour now it doesn’t work . Also had replace transformer . I get 18v to door bell and bypass and chime works . So the unit it self no good .
FiveOenduro, monkeybeas
Given the troubleshooting steps you've mentioned already taken, it may take deeper investigation to understand the issue you're experiencing. I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AlisaD,
If you're still experiencing an issue after consulting an electrician, I encourage you to reach to the Arlo Support Team to investigate this issue and troubleshoot further.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
