We currently subscribe for our doorbell @ $2.99/month. I could care less about 24/7 recording. However I would be willing to pay more if I could get 6-12months more recording history for my doorbell.
We had a package from a purchase during of November of last year that never arrived. In January we complained to the merchant and they pointed out that the tracking indicated it had been delivered. I tried to use my camera recordings to support my observation that it never actually showed up, but by that time it was too late and I could not go that far back in the recording history because of the 30 day limit.
You selected the VMB4540 smarthub as the model number.
If you are connecting the doorbell to a base, then you can attach local storage to the base. With the VMB4540 you can see those recordings in the app, with older bases you can only see them by ejecting the storage, and connecting it to a PC. Either way, it would give you added retention.
I got excited too soon- it seems with USB plugged in it will only record to the local storage and not the cloud. And since I cannot access the local storage through the app from outside my network it's kind of a no go (not willing to setup a VPN or open a port on my router).
Is there any way to configure it so it will store the videos to the local USB and the cloud at the same time?
@cruiserandmax2 wrote:Is there any way to configure it so it will store the videos to the local USB and the cloud at the same time?
If you have a subscription, then the videos are stored in both places.
But there are scenarios where videos only end up in local storage. For instance, if you use activity zones. The processing there is done in the cloud, so out-of-zone recordings still show up in local storage. Also, when internet is down, the recordings will show up only in local storage (assuming the base is powered). Another aspect is that you can't delete files in local storage, but you can delete them from the cloud library.
BTW, I haven't done extensive tests on how far back the app will show you. You might need to eject the card, and look at it in a PC to see files more than 30 days old.
It seems to completely ignore the zone activity settings for the camera.
Correct. Activity Zone processing is done in the cloud and only supresses cloud recordings and notifications.
You can perhaps reduce the amount of local recording by reducing the motion sensitivity in the mode. That's about all you can do with the doorbell since it cannot be repositioned.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
