- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- comment connecter un réseau 2,4 GHz sur android po...
comment connecter un réseau 2,4 GHz sur android pour sonnette DOORBELL WIRE FREE
model AVD2001 , quel mdp il faut mettre? mdp de réseau ne marche pas
Message 1 of 2
293
It connects to your home wifi, using whatever password you have set for that network.
The phone needs to be connected to your home wifi network. If you use a VPN, disable it before the install.
If the installation fails after the chirp, then first look in your router's attached device list, and see if you find the camera there.
Message 2 of 2
290
