- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: Wire-free video doorbell, model number AVD2001...
The images from my Arlo Essential Wire-free video doorbell are disrupted by horizontal pink stripes. I have attached a screen shot to show. Is there anyone out there who can help with this disruptive problem?
Model number: AVD2001
Firmware: 1.2.0.0_624_718aea3_c998ba4
WiFi
Located outside of front door
Many thanks,
Robin
https://my.arlo.com/hmsweb/users/library/share/link/28DB621460DDD072_202211
Does this happen all the time, or just sometimes?
Does it happen both on livestreaming and recordings?
Have you tried removing/reinserting the battery?
Hello Stephen and thanks for getting back to me so promptly.
We will try the battery removal and reinsertion in the first instance and let you know how that went.
In answer to your other questions, the picture interference does not happen all the time. It is an intermittent problem. It happens on the library recordings. I have not seen it happen on live streaming.
Kind regards,
Robin
Hi Stephen,
Can I add a correction to one of my responses to your questions. I have just connected to the live stream from the doorbell camera (this is prior to removing the battery) and I now notice that the pink striped interference is present on live streaming as well (earlier I had said that I had only noticed on library recordings).
Robin
Between the stripes and the very low frame rate, I'd say the doorbell is faulty. Swap at the store if possible or use Settings, Support to start the RMA process.
Just curious if the problem occurs when the doorbell is running on battery only?
Hello,
Yes, this is a battery powered doorbell. We do not have it wired into mains power.
Kind regards,
Robin
