Video doorbell
Cannot set up doorbell after changing router
FWIW, the simplest path is to set up the new router to use the same wifi network name and password that the old router used. Then you don't need to make any changes on any of your devices.
If the doorbell remains in your account, you could still try doing that. But if it is too late for that, then you will need to
- remove the doorbell from your account
- do a factory reset
- add it back.
Step 2 either requires an unbent paper clip, or the release pin that came with the doorbell.
