  • 5 Replies
  • 852 Views
TCPMY
I was unable to set in my location to the device as it auto add the full address which is more than 32 letters and has forward slash.
I tried setting name of building nearby but same problem - more than 32 words
5 REPLIES 5
You should be able to edit the street address - shorting it.
TCPMY
Yes I tried shorten it but the Google location doesn't allow it. It will auto replace FULL ADDRESS even though I shorten it - it auto adds the forward slash and full address.
Hope there is a solution.
Is the browser auto-filling?
TCPMY
Yes, the browser auto fills.
Just turn that off while you set this up.
With Chrome, go into settings and search for "addresses" - you'll find an entry under autofill. You can disable it; it will also also show you a list of the address information that you can edit.
  • 5 Replies
  • 853 Views
