  • 44 Replies
  • 10095 Views
  • 3 Likes
ZeliardM
Hello,
I have a AVD2001 Doorbell connected directly to Wi-Fi. When using the mobile app, live streaming and two-way audio work fine. When using the web browser on my laptop, I have tried Chrome, Edge, and Firefox. It says that talk is initiated, but nothing ever comes out of the doorbell and the mute and unmute button don't work. I have to close out and try again before it will respond, but trying again still gets no audio. I did some investigating to see what is actually happening during the connection for the two-way audio in the web browser using the built-in browser Developer Tools. It looks like it uses SIP over web sockets for communication to connect and send the two-way audio. The whole process looks like the two-way audio connects, it passes messages and acknowledgements back and forth, then after 30 seconds it sends another keepAlive message and then the response is BYE from Arlo and it closes the two-way audio session. Can someone in support look at this and verify and tell me what am I supposed to do to make this work in my web browser? I don't always have my mobile phone available to me and having this work in my browser from my laptop while away from the house is a must have.
44 REPLIES 44
The mods might be able to escalate.  But if you have a subscription, you might also report this to Arlo support (using the support center in the app).  They will likely want you to reset and reinstall the doorbell though.
Are you testing this at home?  If you are on a work network, then it is possible that traffic is being blocked by the enterprise firewall.  So I suggest getting it to work at home first.
Just wondering - if you talk at the doorbell, are you hearing the audio in the laptop speakers?
Also, just in case you haven't done this already - it might be worth checking that the site settings allow the browser to access the laptop mic.  Maybe also check the laptop microphone input level.
ZeliardM
I’m hoping a mod can escalate as I do not have a subscription. I bought it second hand, but have already factory reset and it was a fresh install/add to my account last night.
I am testing at home, on my personal laptop. I have other Arlo cameras that work with the two-way audio in the browser, this doorbell does not.
Yes, I can hear audio from the doorbell in the browser when watching the live stream.
Yes, all browser and laptop settings are correct. I have other Arlo cameras that two-way audio work with in the same browser on the same laptop on the same network.
Just answering questions, I know you’re trying to help and I appreciate it!
Well, you've checked the obvious stuff (which I expected, given your use of developer tools).
The only one I forgot to mention was to make sure that the microphone is turned on in the doorbell device settings.  (I'm guessing you checked that too, so this is a "just in case").
I'm hoping the mods - @BrookeN , @JamesC , @ShayneS ) can help.
ZeliardM
Yep, lol, it works through the mobile app too.
Not a problem, hopefully they can provide some insight.
BrookeN
Thank you for bringing this to our attention, we have reached out to our development team to investigate this behavior. I will provide an update as soon as possible.
ZeliardM
I can no longer log in to my Arlo App or Web Portal all of a sudden.
It gives me an Error Code 400 Error 1110: Unknown Error.
Please advise.
Thanks!
ZeliardM
I am using a secondary account to try and chat with support to get the issue resolved.
BrookeN
Is this on the app or web portal? If it is on the app can you please uninstall and reinstall the app? If it is a web browser are you able to log into the account using a different browser?
ZeliardM
Brooke,
It's both. I have reset my password, tried clearing browser caches, tried Chrome, Edge, and FireFox. Uninstalled the app, reinstalled. Made sure everything was updated. I can use the same username and password to log in to the community portal here and the main arlo.com website, just won't work on the my.arlo.com or the app.
ZeliardM
Brooke,
I finally got back into my account.
Let me know if there’s anything else that I need to do about the 2-way audio issue.
Thanks!
BrookeN
The two-way audio is still being investigated. I am happy to hear that you were able to get into the account.
ZeliardM
When should I expect an update about the two-way issues?
Thanks again for all your help!
ZeliardM
@BrookeN Has there been any update on the two-way audio issue yet?
BrookeN
Can you please do a screen recording for me as well as a time stamp of when the recording took please.
ZeliardM
I can see what I can get pulled together, do you want me to send it via PM or is there somewhere for the case I can upload it to?
ZeliardM
@BrookeN I sent you a PM with a private link to download the screen recording.
ZeliardM
@BrookeN Any update from support?
BrookeN
They are investigating this currently. I will reach out to you as soon as possible.
ZeliardM
BrookeN,
i wanted to follow-up and let you know that i spoke with Support on the phone last Friday.
We went over several different troubleshooting steps, collected some log files from devices that the two-way audio is working in the browser and they are sending the information back to the engineers.
The engineers said they were unable to duplicate this issue. One thing I did note with Support is that the AVD2001 I am having the issues with is not connected to a base station. If the AVD2001 is connected via a base station, in the web browser it uses SIP/WebRTC to connect to the video stream and in turn will use the same connection to connect to the two-way audio and will work. When the AVD2001 is not connected to a base station, in the web browser it uses the older RTSP to connect to the video stream and when using the two-way audio tries to start a SIP/WebRTC connection just for the two-way audio and that is what is failing after 30 seconds.
BrookeN
We are still looking into this behavior you are seeing. I will update you as soon as possible.
BrookeN
This is still being investigated, I will update you as soon as possible.
ZeliardM
Thanks @BrookeN, I appreciate the follow-up. Is there anything else I can do on my end to test or give them more information as to how to duplicate the problem? Or have they found the problem and now they just need to figure out how to fix it?
BrookeN
They were able to replicate it. They are currently working on the fix.
ZeliardM
Excellent! Thats great news, let me know if and when they have something to test and I will be more than happy to test it!
  • 44 Replies
  • 10095 Views
  • 3 Likes
