- English
- Arlo Forum Discussions
- Arlo Video Doorbell Wire-Free
- Turning on notifications for the arlo doorbell ONL...
Turning on notifications for the arlo doorbell ONLY?
- Email to a Friend
- Email to a Friend
Notifications are set in your modes and rules per camera. Turn them on for the doorbell while leaving them off for everything else. I use this strategy with no issues.
- Email to a Friend
Thanks for the reply. Unfortunately, I just realized that I'm not getting any notifications for the doorbell at all. I know the doorbell is detecting motion (the breathing ring light) and it is recording, but I'm not getting any notifications on my phone. Notifications are working as I'm getting them from the other cameras. Any thoughts?
- Email to a Friend
Did you check your modes and rules to verify that notifications are enabled? It might be worthwhile to remove and reconnect the doorbell.
- Email to a Friend
I got the notifications working to my phone now. NOW BACK TO MY ORIGINAL ISSUE. Here's my setup:
-BABY ARLO CAMERA
-ARLO Q CAMERA
-6 CAMERAS (PROS, PRO 2s with Base Station)
-ARLO WIRELESS DOORBELL
I have 9 cameras in total and my goal is to have all of them ARMED but I only want to get notifications from just the doorbell AND I don't want to have to manually check/uncheck the box for each camera every time.
- Email to a Friend
WHy would you need to (un)check the box every time? Once (un)checked and saved, you don't have to do it again. Either you or I are missing something.
You may want to create a custom mode with the needed settings to see if that helps. If you need different settings for different times/situations, create as many custom modes as needed and use the schedule and/or geofencing to switch as needed.
- Email to a Friend
Here's the problem. When I go to create a CUSTOM MODE, I can ONLY SELECT ONE CAMERA to apply this mode to. What I need is for ALL the cameras to continue doing what they're doing, which is recording movement, but not notify me about it, EXCEPT FOR THE ARLO DOORBELL. If you can tell me how to do that then we'd have a solution. Perhaps it's an easy answer. I just haven't figured it out.
If Custom Mode allowed me to select as many cameras as I need, that would be a simple solution imo. Hopefully, I'm just missing something.
- Email to a Friend
