  • 4 Replies
  • 1015 Views
stribor45
I got the new hub VMB4540 and all cameras I have boarded new hub with no issues but I am having troubles re-adding doorbell. Since the doorbell is already installed (screwed) into the wall how would I factory reset it. I tried
  1. turning on/off on power kit
  2. add doorbell without smart hub
  3. add doorbell without smart hub (made sure my iPhone was connected to 2.4 Ghz and I also ensured that I typed correct network name and password.
@stribor45 wrote:
AVD1001 wired doorbell. it worked fine with my old hut but now when i swapped it with this new hub cant seem to be able to add it. since it is already installed (screwed into the wall) cant really reset it
It is a PITA, but you might need to take it down.  You don't need to unscrew it  - instructions for releasing the doorbell are on page 79 here:
But it can be hard because you need enough slack in the wires to keep the doorbell powered.
If you don't have the release pin anymore, you can use an unbent paper clip.
What doorbell model do you have?  Possibilities are
  • AVD1001
  • AVD2001
  • AVD3001
  • AVD4001
stribor45
stribor45
That worked but you were right it was tights. Very little wiggle room due to wires but I was able to reset it and add it to my hub.
  • 4 Replies
  • 1016 Views
