QR code not read correctly on Doorbell AVD2001
  • 389 Views
Umanet
My doorbell was perfectly working but after charging the battery it is not working anymore (no image, not ringing, appearing deconnected in app).
I did a reset.
I followed the procedure several times but still the same issue.
At the QR code step, I push the button, it is blinking white then I san the QR code, there is a sound on the doorbell but it is still blinking white and nothing happen in the app.
Then I click "continue" button, the doorbell is found by the app, then a firmware upadte is done successfully.
But after all the steps, still the same issue (no video, not ringing, ... )
I assume the QR code scan step is not working well because even if I hear the sound after scanning, few secong after it is blinking red.
Thanks for your help
ShayneS
Hi @Umanet
I sent you a new QR code to your email, if you can check and try that one and let me know how it goes.
Umanet
Hi,
The QR code you sent me redirect to Arlo Chime 2 set up.
I have also an Arlo Chime 2 and I have no issue to install it.
Still I don't manage to have my doorbell properly connected after the set up.
Right after the firmware update step, there is a step to properly place the doorbell on the wall.
At this step we are supposed to see the image taken by the camera but I have a black screen.
After I see the doorbell added in the app but it apperas disconnected.
I am a bit disappointed...
ShayneS
@Umanet
I have escalated this for you and Support will be reaching out as soon as possible.
  • 390 Views
