- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- No Wifi connection - Arlo wireless video doorbell ...
No Wifi connection - Arlo wireless video doorbell will bot connect to Wifi on BT Smart Hub 3
Hi, looking for help. I've recently purchased a Arlo wireless video doorbell and I cannot for the love of God get it to connect to my wifi network. I'm currently using a BT smart hub 3 and have a Arlo hub VMB 4000 with 3 cams running faultless. Using the Arlo app on the phone I get the chime indicating the phone has recognised the doorbell followed by the rotating Amber lights on the doorbell button. I am aware initially you have to connect the doorbell to the wifi network before this process and that is where the problem lies. Doorbell searches for my 2.4ghz network for a min or so (with the flashing white lights around the button) only to be followed by the amber lights of dooooom...!!!
FWIW, you cannot connect the AVD2001 to your base - right now it only connects to your wifi. Arlo has said they will add this feature, but they haven't said when.
Do you mean that the doorbell is chiming? That means it's read the QR code.
Have you checked to see if the camera shows up on your router's attached device list?
What router do you have?
@andysaxon wrote:
Arlo have clearly stated in posts well over 12 months ago that the option to record locally to usb from wireless video doorbell is now available on vmb4540 and vmb 5000.
No they didn't. They've repeatedly stated that they were planning to add it for the AVD2001, but never said when. Hopefully soon.
If you have links where Arlo said something different for the AVD2001, then post a couple of them.
