Installing the chime 2 tips
I could not get chime 2 to connect to wire free door bell. I think Arlo need to change their instructions for how to achieve this !!! I was using an android phone. The step which seems to be missing is this:
Before you start , on yr phone wifi settings forget your WiFi connections to yr router. Then in the arlo app go through the process of adding the chime 2. This process worked immediately after many failed attempts I believe because the chime needs to use its own WiFi to communicate with the doorbell.
Hope this helps
0 REPLIES 0
