- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- A6E323AG065CF Not sure if I am using the correct c...
A6E323AG065CF Not sure if I am using the correct cable which came with the Arlo Wireless Doorbell
I am not sure what the battery lights mean while charging. I don't know if I am using the correct cable which came with the Arlo or if I am using another from my basket of chargers. What are the lights i am supposed to see when the battery is correctly charging?
Hey @chrisstephans
When you plug your Doorbell battery in to charge, you should see a Red LED light on the battery. When fully charged this will change to green.
