- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- I changed my password and ID on my internet. Now I...
I changed my password and ID on my internet. Now I can’t get my doorbell linked.
I changed my password and ID on my internet. Now I can’t get my doorbell linked. I have two other cameras and a base station that linked up, but my doorbell will not for some reason. I have been told that my doorbell will not link to my base station, so I have to link it separately. FYI - even though this is a wireless device, I have it wired. Can anyone help?
That will trickle-charge its battery, and let it ring a mechanical chime. But it is still using WiFi to connect. In the case if the AVD2001, it is using your home WiFi, since it can't pair with a base (yet).
One option you could try is to set up a guest network on the router that uses the old WiFi network name and passphrase. The AVD2001 should then connect to that guest network. Connect your phone to the same network, and then use the app to move it to the new network. When successful, you can remove the guest network.
The other option is to remove the AVD2001 from your account, reset it, and then on-board it from scratch. https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
