  • 991 Views
ArtDirDave
I want to selectively disarm some cameras but not others. For example I never want to disable my doorbells. Can you do it? And if not let’s get that option
Yes. The details depend a bit on whether you are using base stations/smarthubs or not. Can you clarify your setup?
ArtDirDave
I am using the Arlo Base Station from Arlo VMB4000r3
Assuming the doorbell is also connected through the base...
What you do is create one or more custom modes for the base.  These contain rules for the cameras you want to arm.  Any cameras not included in the rules will be disarmed when that mode is selected.
The custom mode(s) can then be scheduled and/or used in geofencing.
  • 992 Views
