- Email to a Friend
How can the siren option be disabled to prevent inadvertent siren activation when a motion alert is triggered? We want the notification so that we can check the video feed and possibly interact with a person, but don't want any chance of accidentally triggering the siren.
- Email to a Friend
I think I got it now - it's the NOTIFICATION that has the option for turning the siren on. No, you can't remove that.
All Replies
- Email to a Friend
That setting is in your modes and rules. It's off by default so someone must have enabled it there.
- Email to a Friend
There's no setting to completely disable the siren. You can trigger it directly with motion (or not) and you can enable or disable push notifications. I want the notification without any possibility of then having the siren turned on.
- Email to a Friend
- Email to a Friend
When that option is on, it instantly triggers the siren on a motion event. Unchecking it does not remove the siren option from the notification.
- Email to a Friend
- Email to a Friend
Thank you anyway for considering my question - your time and patient responses are appreciated.
