Chime 2 doesent connect
Hi..
i have got a Chime 2 that dosent whant to connect.. i have been talking to support, and they has sending me a new one.. but the same problem
When i add it, i got asked to gonnect to Wifi Arlo-2574, but it stop there…
can somone help please? Have been using 3-4 days with this…
Hi @Olarsen96
What is the error message after you select Join, what is the screen you get stuck on?
Are you connected to a 2.4Ghz network while onboarding this chime?
Yes, 2,4
the message is « could not connect to Arlo Wifi 👍🏻
i have tried all, and i have seen in the comnunity rhat is many that have the problem. Arlo had to fix! Have been working with that MANY days now
No
yes
@Olarsen96 If you adjust to WPA2 does that help with the onboarding?
No… it dosent work…
please fix this nowå
Can you provide your case number and I will look in to this.
Case numer is. 00572073
have tried 2 of them noe, and i can see that i am not the only one that have that problem…
Thank you, I notified support and you should be receiving a follow soon.
