  • 5 Replies
  • 1251 Views
Rumen0105
Had a real problem connecting the Chime 2 for second time,it was working ok before ,then suddenly lost connection to the router,I then set up different 2.4 gh network, connected it ok and then it stopped working.
I tried to reset, remove and add it again and none worked.
Thanks in advance for any help
5 REPLIES 5
Have you tried resetting the chime?
https://kb.arlo.com/000061879/How-do-I-reset-my-Arlo-Chime-or-Chime-2
It may just be faulty so swap at the store.
BrookeN
@Rumen0105 what type of phone are you using  to re-onboard the Chime 2 ?
Rumen0105
Thanks for reply, phone is Nokia xr21 , been working well before
BrookeN
It looks like it is online as of now. Are you still seeing the same behavior?
Indigo123
I recently had to reinstall my Chime 2, and had issues.
I found two workarounds that has solved it for me:
1) Set up your router/wifi to only broadcast 2.4 Ghz (and switch off the 5Ghz) if it broadcasts in dual bands
2) My iPhone 14 cannot make the Chime connect to the Wifi, but I can do it via my old iPhone 7. It makes no sense, but for some reason, my old iPhone 7 can easily connect the Chime to my router, but I can never do it with my newer iPhone.
These two fixes solved it for me, as I was starting to rip my hair out.
  • 5 Replies
  • 1252 Views
